Firstly, I have used this forum section as it seems the best for a gas regulation query.
We are replacing our cooker. Although it is 'free standing' it fits perfectly into a bespoke space between work surfaces and has a glass lid & low level grill.
It is connected to the gas supply with a flexible hose and 'twist & lock' connector.
The supplier has informed me that it must be connected to the gas supply supply by a GasSafe reg engineer and that flexible hoses are not supplied with new cookers. Evidence of this is required to validate the guarantee should we need to call on it.
No problem on the above and would want this for safety reasons.
However, they have also said that all free standing cookers, if connected by a flexible hose have to be stabalised with a bracket which anchors the base of the cooker to floor. I presume this is to prevent accidental movement of the appliance.
As the cooker will be held rigid between kitchen units and work surfaces is this necessary. I ask because I can foresee problems in accessing the base of the cooker when it is place.
Can anyone please advise on this - thanks
