gas smell
1 Oct 2006
moved in a new house recently,got a ideal classic standard gas boiler in garage with a fanned flue, when it first comes on eg heating or hot water is it normal to smell gas outside answers appreciated thanxs
on ignition then yes, there may be a small quantity of unburnt gas. but ONLY on igniton.
thanks for reply rob yeh its only when it starts up then goes after a while then when boiler turns on again u can smell it again so yeh it is after ignition
I think there may be a viewing window on the front of your boiler.
You may be able to see a spark which lights a pilot and a second later the main burner lights.
If there is much of a delay at any point unburnt gas will be expelled from the flue.
Tony
