Need to tap into gas pipe in order take 22mm feed to boiler position...need some advice please.
Gas pipe to meter is vertical and right up in the corner against the walls. Need to tap into it with a T - what type of T connection is best compression, capilliary or ring solder. Are normal compression fittings suitable for gas?
The pipe will run through an internal double wall - does it need sleeving? if so, what is best to use...at the moment I have 15mm pipe with no sleeving.
I think I feel competent...
