I intend to use an existing run of 15mm copper to supply bottled propane to a hob - roughly 10m. The pipe run was installed to supply a fridge but never used. The hob will be re-jetted and installed by a CORGI installer as well as the gas changeover valve to switch between 2 bottles located outside.
I want to fit some cabinets which will make part of the relevant piping inaccessible. How can I go about gas testing the existing pipework before the gas fitting is completed? If I can establish the existing copper is gas tight, this will hopefully minimise the need to access the joints hidden by the cabinets.
