What are the Pro and Cons of changing from Gas to Oil. Daft question but does a CH Engineer do both Gas and Oil installations. Got opportunity to buy new Oil CH Boiler but don't know whether converstion is good idea. All comments welcome.. Thanks
Do you really want an oil tank (unsightly !!) on your premises, location must be where it is accessible for filling; (must also remember in good time to arrange filling)
Fluctuating oil prices - outlay for refill cost could vary considerably from refill to refill, also large outlay at once rather than cost spread over quarterly gas bill.
May also be worth checking with estate agent as to whether oil fired instead of gas C/H has any effect on the value of your property.
Companies will deliver at short notice if you have a problem. Problem solved.
True but basically the answer to the original question is no, it wouldn't be a good idea to change from gas to oil if you are already currently on nat. gas, even getting the boiler gratis there are substantial costs to setting up an oil installation.
