I have an irritating problem which I am hoping has a solution.
When the water leaving the boiler reaches 70C and higher, gas bubbles form, which causes noise in the first available radiator.
3 - 4 months ago the system was flushed, Fernox F3 added and left in for weeks, then flushed again repeatedly. The boiler heat exchanger was also de-scaled using 13% sulphamite for 3 hours, flushed again, then the system refilled with clean water with the correct dosing of Sentinel X100 inhibitor and Sentinel X200 noise reducer.
In spite of all this bubbles form at 70C and above.
I keep venting the system manually, mainly from the magnaclean unit and the 2 noisy radiators.
Does anyone know what I can do next to eliminate the formation of gases, which I presume is not air but the production of hydrogen being released from the water?
The CH comprises a sealed heat only boiler (Potterton Netaheat Profile), expansion vessel kept at 2 bar, and HW cylinder via a mid-position valve. There are 13 radiators. Prior to cleaning there was a small amount of kettling at the boiler but it is now entirely eliminated by the sulphamate descaling and X200 subsequently added . Prior to flushing the water was very dirty with magnetite, but now appears clean judging by the clear water seen when bleeding the radiators and removing the magnaclean element.
I want to allow the boiler to reach its maximum of 82C when necessary, and not have to restrict the flow temperature to 70C in order to avoid gassing. Presumably this is not asking too much?
Is installing the Spirotech aerator the way to go, or are there other things I can do to stop the gassing?
Would really appreciate any advice on this, and thank you in advance!
