I need to replace the the feed side isolating valve of the pump. The ball valve is cheaper. Is there a disadvantage to it? It is known that ball vales are not good for throttling. But, throttling will not be needed for this application.
OK, schoolmaster, thanks for the info. It's starting to make sense to me now.Re. post #3.
1. Better build and materials quality.
2. The square on the spindle allows a spanner to be used to open / close, rather than a screwdriver slot which tends to get chewed up.
3. If you are seeking advice, perhaps better not to use schoolmaster phrases like "care to explain".
Yes, black carbon. I have just put everything back. I will use a magnet on them next time. I am not convinced they are magnetic. But, this is not to say I am right. They resemble the same black stuff in car combustion related chambers. If they are proven to be magnetic then I will consider a filter. It's quite apparent the central heating cleaners are a load of bull oxes. These have no effect on the black stuff to soften or dislodge them.?carbon?
Do you mean black deposits? Iron oxide.
Have you got a magnetic filter yet?
