Hi I'm going to install a new 0.9 x 1.8m wooden gate on the side of the house with a fence running from this to the fence along the boundary of the property.
The only thing is I plan to use 75mm fence posts for the gate (the hinges will be on the one connected to the wall) - the fence will join the other post at a funny angle, probably 150 degrees. Could I bend some angle brackets and use these to fix it to the post or is it possible to get the post cut lengthways to the angle I need?
Also would 75mm be heavy duty enough? The fence is also going to be on a bit of a slope so I may have gaps to one side of each panel (I reckon 2 1/2 panels at most)
