Gate valve mystery
14 Jul 2004
I may be about to show my ignorance but....
My hot water cylinder has (amongst others) two pipes of interest: one exiting mid-way up and connecting to a 3-way electronic valve that's wired to my boiler timer and the other exiting at the bottom and linking up to the middle down pipe of the 3-way valve (stay with me!) via a gate valve (the one with the round red handle). This valve is now leaking.
I'd imagined that it would be fairly simple to replace the valve: turn off the water, drain the tank, fit new valve etc. My only concern is that the pipework gets hot when the central heating is turned on. I have a sealed pressurised system that I had (perhaps naively!) assumed was completely independent of the hot water system.
Am I missing something here or are the two systems in some way linked and the job is not as easy as I imagine, or is it some strange coincidence and the job a straightforward one?
I think I'm getting a better understanding here! Have a look at this link:
http://www.diydoctor.org.uk/projects/domestic_hot_water_systems.htm
My system looks like the picture on the right (indirect cylinder): Pipe #3 is connected to the leaking gate valve and pipe #4 to the 3-way electronic valve.
The implication from this article is that the hot water is heated as a by-product of the central heating system. My hot water can be heated independently from the heating, so is it possible that the electronic 3-way valve (connected to the boiler timer) is used to select either a direct boiler feed or a feed from the heating system?
So where does that leave me? I'm not sure what I have to drain to remove the valve!
By the way, the valve is leaking from the point the spindle enters the body.
I tried tightening but that briefly made things worse! I may have another go and see if I can stop the leak.
If that doesn't work, any ideas on what to drain?
I'm moving in January, so plan B may be to put a drip tray under it for now until it becomes someone elses problem!
would think its a balancing walve for the hot water side
if you turn the system off
close the valve (count the turns )
remove the red wheelhead
remove the gland nut (top of the valve )where the spindle enters
wrap a couple of turns of thread tape round replace the nut/head etc
open the valve to where it was then tighten the nut a little more
if you need to renew it its a drain down :cry:
