I have too Gate Valves in my airing cupboard, both sitting on separate pipes coming from the cold water tank in the loft. One is going to the hot water cylinder and the other is the cold water feed for bathroom and toilet.
My problem is that both of them are very hard to turn and do not shut the water off completely. One is making a bit off a crunching sounds when being closed. So if I have a water leak it is not ideal and I need to fix the problem. I suspect there is some rubbish or maybe limescale in the valves that prevents them from working properly.
1. Can I take them apart a "service" them without changing the whole valve? If so can somebody explain how?
2. Or would I have to change them (which I would like to avoid as it would involve pushing the pipes up in the loft a bit in order to remove the gate valve).
Thanks !
Thanks !
