Is there any difference in the aplication of these. Like most i've had problems with seized gate valves while ball valves or even isolator valves seem to be better. Thanks.
Ball valves sometimes have a tendency to leak from the spindle. If you decide on these you should ensure that you purchase full bore ones or you may suffer from flow problems.
