There is a gate valve on our hot water heating system - 22m - fitted on the return run of the HW heating pipe. Should this valve be fully open? Plumber who 'installed' our system had this barely open.
Its a bypass to stop the boiler overheating if all the trv,s shut down. You also have one on some boilers with a low water content heat exchanger. It should only be open a little. Dont shut it fully.
