Gates and Cranked Hinges
22 Feb 2010
Lancashire
Hi all,
Just wondering if any of you have fitted cranked hinges the wrong way round.
I'm making some driveway gates, and i'd like them to swing both ways (oo er!).
I'm planning on fitting the hook 'inside' the opening rather than on the back of the post, i was wondering if by fitting the cranked band the wrong way (ie crank forwards and not backwards as normal) would it give me enough to throw the thickness of the gate away from the wall as it swings? (obviously that'll depend on the thickness of the gate, but you get the idea)
Does any of that make sense, or do i have to draw it for you too???
No need for a drawing, fill your boots and let us know how it goes ..........
Of course. A cranked hinge is only used to cut down on the gap between the pier or post and the gate itself and also to throw the gate forward so it sits in the opening.
But a cranked hinge can only open one way as its mounted on the front or rear face of the pier.
You just want a normal flat hook and band hinge or field gate hinge as they will project it further out from the post and rather than mount it on the rear face of the post like this
http://i1.ytimg.com/vi/5KPCIysmVk8/maxresdefault.jpg
mount it on the inside face of the post like this
http://www.mcveighparker.com/mcvp_store/images/uploads/KWF_hug.jpg
The only key thing here is to get the spacing of the posts right as you have less room for adjustment.
Thanks, i'd seen field gate hinges but i'm not sure if i can get one the correct width. Either way, i was going to mount the pin 'inside' the opening, and cut the gates to suit
I wish to see the on going improvement and changes on your gate. Your idea is just out-of-this-world and I think that this is achievable especially with your motivation and goal.
