ok i will explain the setup as it was before I messed abouttried to sort it out.
In wall I have phone socket, in phone socket I have 'filter' which has phone (landline) and modem (for broadband) plugged in it. Thats how it all works fine.
Now I have a Wireless Gateway box
Now the way I am reading things this Gateway DISCARDS the modem. and the gateway acts as a modem? is this right??
The instructions say NOT to put gateway into filter! but the gateway connecting wire is not right size end for the phone socket in the wall. so now i have a double connector thing so I put that in the phone socket in the wall, plug the filter into it with the phoneline (landline) into the filter so i can use the phone, and plug the gateway into where it says modem on the double connector thingy. the gateway has another wire (ethernet) which goes from the gateway into my pc.
so in effect, I have the gateway plugged into the phone socket in the wall (via a connector NOT a filter), the filter with the phone (landline) plugged into it is also plugged into the wall socket with the double connector. The ethernet wire is plugged into the pc. and it wont connect
If my broadband modem has to come into it somewhere i dont think i have enough holes
