gcol ! want to lay ceramics out door on concrete slab.
First make sure they are frost proof, you will be better off with porcelain but still make sure its frost proof.
Use a powdered adhesive and grout that are both suitable for external use such as BAL Rapidset & BAL wide joint grout.
You will need to use a tickbed solidbed trowel (large half round notches) as you don't want any voids under the tiles.
Jason
As Jason said, go for a Porcelain tile and use 10mm Radius U-notched trowel. BAL stuff is good tackle but very expensive so I only use their stuff when tiling onto wood. For tiling onto concrete you don't need anything special. I always recommend Feb fastset floor and wall tile adhesive and PCI fast track grey grout . Both can be used outside and are pretty cheap:
Adhesive: http://www.cwberry.com/Inquiry_ProductDetails.aspx?ItemNumber=04054505
Grout: http://www.pci.uk.com/product_fasttrack_grey.asp
