GE Dishwasher Won't Drain! Hate doing dishes - please help
30 Apr 2007
I have a GE Dishwasher, Model # GSD2200G00WW, that won't drain. The line is not clogged. It drains in to a garbage disposal, which is operating fine, and there's no air bubble to test.
Underneath the washer there is a plastic "arm" that is operated by a spring that hits the top of the solenoid which I can trigger manually to get it to pump/drain out. Not sure what activates that to engage. I'm assuming the timer. Not sure if the solenoid needs replaced or if it's something in the main dial/timer on the outside front that's messed up, or something all together different.
Any suggestions would be greatly appreciated as I would rather clean 100 toliets than hand wash a sink full of dirty dishes! :mad:
