most jigsaws are a lower wattage than that, so the answer is probably yes, but check your jigsaws wattage and keep the extension lead to a sensible length.
A generator giving out 850watts, should power a jigsaw consuming 500 / 600watts
With the correct saw blade and taking it easy, you should manage to cut 40mm.
