gettin my loft converted soon
31 Oct 2003
just wondering if i can get these removed otherwise i`m fooked
as theres this chiney stack now unused blocking my route to the main part of the loft
as you can see its the same the other side
more pics can be supplied if you need to see more
Actually they are supporting your roof pulins, pull them away without correct support and your roof will sag, you need them supporting with some structual stud walling or purlin jacks built off an internal wall or off a series of floor girders that will support your new floor.
I'm not been a wet rag here, but need to get some expert advice before you going pulling things out, also you will need building regs for this kind of work
