getting a fall on guttering
10 Jan 2007
how do you go about getting a fall on guttering for water to run smothly
String line over 2 brackets @ either end of run :idea: " A line and a rule guide many a fool " worked for me for 30 years ;)
Fix one end lower down the fascia than the other? :rolleyes:
Gutter does not really need a big fall - it will empty out of the outlet as it fills up
Do as others suggest - when you fix the third clip grab a spirit level and lay it between two clips - you will then know if you have some fall on it.
