Having taken down a dividing wall between toilet & bathroom (to make one bigger room) I have gaps in the ceilings, with joists showing, and the existing PB also has horrible textured paint on it. I'm going to put new PB sheets (1220 x 900) over the existing ones and then skim, but I'm concerned about getting the joins level.
I was thinking about using PB adhesive to bed the sheets into, so that when I screw the boards into place I can compress the adhesive dabs slightly and get the sheet joins exactly level. Is this OK, or should I just screw up tight to the boards above and hope for the best?
