Our lounge ceiling is papered with Anaglypta and is very uneven. We have had a plasterer look at it and he suggested it would need re-boarding and skimming with plaster. We are concerned for our carpet, wallpaper and other fixtures in the lounge
Our alternative was to DIY and use some Dumaclip PVC panels and the plaster was of the opinion that this would be a cleaner and safer option
I have started to fix 30mm X 16mm battens to the ceiling but I am amazed at how irregular the ceiling is and after spending a lot of time packing behind the battens I am not confident that some irregularities will not show through the panels. I have used the panels before and know that it only takes a couple of mm to show
Should I:
1. Keep packing and make the best job that I can
2. After packing, fit cross battens to improve the levels, and fit panels in opposite direction
3. Abandon packing and call the plasterer back
TIA
Should I:
TIA
