getting power to home projector
13 Mar 2010
London
What do you consider the best way to get power to a ceiling mounted projector and screen.
Was thinking of taking a feed of the lighting circuit to power the screen motor
which is between 40-90 watts.
I do not know the make of the screen but I presume it will be remote control with no need to provide a wall mounted switch.
The projector is about 300 watts, not sure how to power this, dont want to put to much on lighting circuit.
Any tips advice on getting power to this unit would be appreciated., and a neat solution for bringing the cables through the ceiling
From a safety perspective taking power from the lighting circuit is a bad idea. Devices & sockets should be on a separate circuit to the lights.
I realise you'll probably say that no-one but you will work on the system, so this won't be an issue, and that anyone should test before commencing work; but one can never tell what might happen.
If it's your flat then have the spurs run up the walls properly, or at a push take power from the upstairs ring main if it's a house.
Stick a flush mount single socket in the ceiling, that's what I did.
