I am wanting to run a cable to a shed in the garden which sits about 1m away from the side of the house.
I want to run the cable externally preferably clipped into a mortar line about 8-10foot high.
If I were to buy 10mm SWA cable, how good is it at bending 90degrees around corners?
I primarily want the cable to power a shower in the shed, but it would be great to run a double socket and a fluorescent light off it too, is this possible?
Can I run the 3 things off the one 10mm cable, and just have 1 breaker at the main fuse board labelled "Shed", or would it have to be 3 seperate cables with 3 seperate breakers, "Shed Shower" "Shed Light" "Shed Socket" ?
I've seen cables ran to an outside shed before and as the wire had to travel through the air to get to the shed, there was a metal tube screwed to the house and screwed to the shed above head height which the cables were situated inside, do these have a special name?
Thanks in advance
Thanks in advance
