After cleaning off the adhesive you need to wax the area otherwise the marks will keep coming back.
I normally use petrol to remove the adhesive followed by "T cut" or mild rubbing compound and then a good polish with a wax, such as turtle wax or similar.
Unless the van is almost new you will nearly always be able see where the stickers were, which is due to the surrounding areas being effected by the sun etc.
