Hi all,
I need to silicone in around a upvc cill. My past attempts have had mixed results, usually I tape either side of the gap leaving a gap the size I want the silicone to finish at.
I'll then apply the silicone, wipe the excess off then remove the tape then smooth the bits the tape raised up which as often as not leaves an untidy edge.
Should I be leaving the tape on till the silicone is dry, if so how do I then remove it as the silicone will be stuck to it?
Chris
Chris
