we had some issues with penetrating damp which has been traced to some cracked render (roughcast or pebbledash - from the 1930s, with semi-smooth stones I think, painted over) on the rear wall of the house and the chimney stack. We are in the process of getting quotes to have this repaired.
Both quotes so far have suggested removing and repairing broken sections, using a base coat, a mesh, then the top coat. One said he would use krend, the other didn't specify (I've asked for more information).
One has suggested just patching, the other patching, plus going over all the roughcast on that one wall. So the broken stuff is removed, then the whole wall is gone over for a complete new coat of rough cast.
This would all need to be painted, since the whole house is already painted.
Anything I should be aware of, or look out for when getting these quotes? I've already asked them for a more detailed breakdown of materials and processes, so I can post that back here.
I have read conflicting things online about putting roughcast over roughcast - some suggest it's fine, others that it's not.
I am also unsure of whether the original roughcast was cement or lime based. Is there an easy way to tell, and will this affect what can be put on top?
Thanks for any information,
g
g
