I'd like to build a glass block wall in my conservatory to try and divide the room into 2 distinct areas. Ideally I want the wall to be about waist height - so 6 or 7 blocks.
My problem is securing the wall.
The conservatory is the width of the house and I'd like to split it width ways. The external wall of the house has a radiator on it which will make it hard to attach the frame for the glass blocks at that end. The opposite wall is a full height glass panel, so nothing to attach it to there if I was to mirror my plans. There's a piccy below to try and show you what I'm talking about.
I've never worked with glass blocks before, though I have read about both the dry fix and wet fix methods of installing them.
It's probably worth mentioning at this point that the floor is ceramic tiles.
Will either the dry fix or wet fix methods be strong enough to hold the wall without supporting it at either end? (Obviosuly I'll drill the floor and secure the base of the frame).
I have considered making/getting some metal brackets, attaching them to the wall above and below the radiator and bending them round to give me something to support that end of the frame.
Ideally, I wouldn't have the L shape at the other end, but my thoughts are this would add support to the other end of the frame?
Let me know if I'm about to start a project destined to fail!
Many thanks!
Many thanks!
