- Joined
- 14 Apr 2017
- Messages
- 1
- Reaction score
- 0
- Country
We are developing a small block of flats. The communal stairway and one of the external walls of one of the apartments has a section of glass blocks to be installed.
Having not worked with glass blocks before this is all new to me. All glass blocks appear to have 60 minutes fire integrity and either 15, 30 or 60 minutes thermal resistance. We have asked the BCO what we need to install and he said "60 minutes fire rated".
We can't get a better answer from him (is fire integrity the same as fire rated?) so I'd hoped Part B would make it all clear (apparently not). The wall in the communal stairway is the external wall. I understand the need to protect the walls between the apartments and the stairs, because fires usually start in one of the properties, but the external wall?
Our problem is that glass blocks range from about £3 to almost £20 each, depending on the thermal resistance and that could cost us a small fortune.
Anyone know the rules of glass blocks and fire ratings?
Thanks,
Geoff
Thanks,
Geoff
