The pump between the boiler and storage tank runs continuously.
The boiler, a Potterton Suprima system boiler, was fitted with a new heat exchanger and a PCB in 2011. At the same time a new ball valve and anti-corrosion fluid was fitted to the expansion/makeup tank on top of the storage tank.
In recent weeks have become aware that the pump runs 24/7.
I know that the boiler requires the pump to run on for a few minutes after boiler shutdown to dissipate residual heat from the cast iron heat exchanger.
The Boilermate 2 also has the ability to do much the same but only to extract the last bit of heat from the boiler on shutdown.
Not sure if one or both conditions are enabled but it would seem at least one of them isn’t eventually switching off the pump when the storage tank temperature thermostat has been satisfied.
Have read a number of posts on the subject, the problem is not uncommon.
I ask if anyone have had a successful, and not too expensive, answer on what is the cause. I am thinking it a faulty Delay Timer PCB on the Boilermate.
Any advice would be appreciated.
thanks
overthetop
thanks
overthetop
