I will shortly be installing a Gledhill Boilermate 2000 on an oil fired CH system with all TRVs.
Before buying the Gledhill I was intending installing a std cylinder and with this in mind I bought a Danfoss Alpha pump to cope with the TRVs.
Question - can I install the Alpha in place of the original CH pump fitted to the Gledhill, or do I need to get a bypass valve instead? I'd prefer to use the Alpha if poss, but I don't know if the variable speed will cock up the Gledhill's operation.
Any thoughts???
Any thoughts???
