I have two problems with this 'device'. It has a separate header tank in the loft and the boiler is beside and slightly above. I have got the boiler thermostat on high and the tank half way such that the boiler is controlled by the Boilermate OK. First problem is the header tank pipe is very hot and the water in the header tank warm. I have not noticed this before and it might be normal, that is quesiton 1! The second is the hot water to the shower and bath starts off nice and hot and then goes luke warm. I have adjusted the mixer valve and when one puts it to cold the water is cold, putting it to fully hot it is only warm and the outlet from the Boilermate is also only warm. Is this a bunged up coil? If so, how can I clear it please?
