I have a Gledhill BoilerMate 2000 in a property which is 4 years old. The right hand pump (which I believe circulates primary hot water through the heat exchanger and back into the store) joins onto the boiler with a copper pipe and black rubberish seal. When the system activates to bring the water back up to temperature, water appears to come from the area around the seal and drips down the side of the metal casing. This stops as soon when the system stops heating the water in the thermostore. The problem has been obviously been ongoing to a small degreee for a year or two (judging by the water marks, limescale and mould under the system), but must have suddently got much worse.
I suspect the leak is occuring from the pipe around the seal rather than internally, and am hoping that it may be fixable. However, any advice would be gratefully received. I have had advice from a couple of plumbers, but neither were familiar with the system.
