Hi Gurus out there,
I have a Gledhill Pulsacoil 2000 installed at home, which is now around 5 years old, but the booster switch on the wall connected to the boiler, seems to be broken so that I can't switch it on at all.
The switch used to get stuck in the OFF position before, so it was hard to switch it on, and it became very hot about it while it's on.
Interesting thing is we own another flat nearby which has got exactly the same boiler and switches and also the same switch problem, but this time it's stuck in ON position so that we have to switch on/off the main power switch whenever we need/don't need hot water, respectively.
I tried and opened the booster switch box on the wall to see if I can fix/replace it myself but to find it's way more complex than I thought.
Can anybody give me some advice on this problem, what to do for this.
Thanks,
Thanks,
