Gloss, needs repainting....how to
16 Mar 2007
Norwich
Hi All,
we are in the prosess to redecorating the entire house, and so, we have doorframes/window sills that all need a new lick of paint.
At the moment eveythings gloss white, and I would like to repaint them in white gloss. Can I simply repaint them with a new coat of gloss or should I sand them down a bit (or alot), prime them or somthing?
cheers
as long as the original paint is in good condition, just give them a light sand, and re gloss.
cheers Eddie,
the original paints prettty good, just a few chipped parts here and there from use over the years
Hello,
From my experience I would give the woodwork a good rub and apply an undercoat then a gloss. The undercoat gives a key for the gloss to stick to. If you apply gloss onto gloss, in a matter of time the top gloss will chip away if knocked, whereas if you apply undercoat and gloss this is more durable.
Hope this helps
D
I use oil based undercoat and gloss. Either Dulux or Crown, both as good as each other.
D
