Leaking boilers.... I hate them.
I have a problem with a glow worm 24cdi. There is a leak coming from the front of the heat exchanger, and as a result the burner is coming on for 2 or 3 seconds and then going out. After about 3 attempts it goes into lockout with F1 fault code.
Is this a leaking heat exchanger or a condensate problem?
I have the feeling that as it dripping without the burner having and work that its a heat exchange problem. Would you agree?
