After getting up this morning to no hot water I've been poking around having a look to see if I can see or diagnose a problem.
Whilst looking i seem to have found a small leak as well and I'm not sure if it's related or not.
Symptoms :
- No hot water
- Very Luke warm for first few seconds
- Light comes on and switches to show pressure.
- CH flow pipe remains cold.
-If left running for a while once tap switched off if I turn it back on the light doesnt light and pressure not displayed.
I had the P2P heat exchanger cleaned last year as that was blocked. Although that caused a fault code to show.
I'll attach a picture of where I found the slight leak. It's from the nipple ar the top of the part behind the main pump in the picture.
Any help would be appreciated.
Symptoms :
- No hot water
