Hope you can help, I have tried to search the forum but can't seem to find the answer. . I have a Glow Worm 30CXI Condenser Boiler. Today I opened the pressure filling loop tap, as I do every now and then, just to make sure the system is properly full. However, this time, water started leaking from some sort of vent valve to the left of the tap (as you face the front of the boiler). This has never happened before and is a bit of a worry.
The boiler seems to be working perfectly well with a pressure of 1.1 Bar.
Any help is most welcome.
