- Joined
- 21 Apr 2009
- Messages
- 2
- Reaction score
- 0
- Country
Wonder if anyone can help me. I have a Glow-worm 38cxi boiler which was installed in Autumn 2005.
We have had some issues with water temperature over the course of the last few months.
The heating seems to work fine. The first problem was that when the hot water (for the shower) was turned on it became hotter and hotter and hotter until the boiler eventually cut out. (F14 fault which, according to GW's helpful! manual is central heating flow temperature more than 95C). Normal taps were okay although the heat of the water in those was not what it should have been.
Our plumber thought it was a diverter problem and changed that (to no avail). GW then indicated to him that there was a problem with some switching pin in the boiler which was changed yesterday. This has not solved the problem and having spoken to GW again, he has been informed that it is the heat-exchanger that needs replacing.
However, since the work yesterday the hot water is now almost non-existent. We can't get hot water to the shower at all and the boiler is cutting out (still F14) after about 5-10 seconds of the hot water tap being on (even though the boiler temp appears to be only about 65C ish)
I am not a plumber and have no knowledge about boilers or central heating but am becoming frustrated with GWs apparent lack of knowledge about their own system and our plumber's fruitless attempts to solve the problem.
In my own mind I can't understand why the heat exchanger would be a problem if the radiators are heating up fine but the water isn't. Maybe that is my lack of knowledge coming through.
Anyway I have seen other posts about GW boilers and they are less than complimentary but I am loathe to rip it out and start again when it is only 3 years old.
Any help would be greatly appreciated.
ColdWaterRich
ColdWaterRich
