I hope someone can help.
The pressure in the boiler dropped to 0.5 bar, twisting the tap extender thingy at the bottom made no difference. I read that this part is often problematic and so I removed the tap and I could see that the white dot was still in place. So I poked it in and refitted.
Water started to flow again and the pressure increased... in fact too much! Then water began to drip then dribble out of a pipe underneath the boiler and the pressure continued to increase.
It's resulted in me now having to shut of the water supply completely. The leak is coming from the pipe that joins the refill pipe.
Any thoughts, please?
