Hi all,
I have a Glow Worm 38CXI boiler (one that is 6 years old) and my hot water temperature has started fluctuating, so much so that when you hold you hand under a hot tap it goes from nice and hot to luke warm and then back again. Say hot for 30 seconds then runs luke warm for 10 seconds then back to hot... repeats...
The diverter valve inserts and motor were changed last year ( leaking valve seals water logged the motor!) while the boiler was still on a service contract, at the same time the heat exchanger was removed and cleaned, but not found to be blocked or containing any sludge as we were suffering slight fluctuations in water temp back then.
(we also use softened water and have never had a problem with sludge or lime scale.
Is there anything I can try to fix this? or does anyone have any ideas what else it could be, water flow is about 13 litres/min (boiler is rated for 15 from what I can tell. Could it be a thermistor/temp sensor somewhere? or a flow sensor?
Central heating seams to work fine.
Any help appreciated.
Dan
Dan
