I have a glow worm ultimate 40ff boiler with a danfoss 4033 timer. This week I have soldered up a few dry joints in the PCB this week and replaced the R11 resistor as it wasn't allowing the boiler to fire up it was just "cycling" if that makes sense. And all seems to be ok again. I thought I would tackle the issue of the CH pump running all the time. I thought this was down to some wiring issue up in the wiring centre next to the HW tank.
But on checking the pump it's getting a constant feed all the time. Back at the PCB end I have disconnected all the wires going out from the PCB choc bloc conector to the timer unit just leaving the mains feed to the PCB. I am getting a constant feed out of I think it's the purple wire (pump feed ) off the PCB,upto the choc bloc connector.This is even when the boiler is off and has been off all night . could this be another quick fix within the PCB or is it a common fault and am I better off getting another PCB.
Thanks for any help.
