Hi, i have a this problem with a Betacom 30c:
The fan starts as soon as rthe boiler is switched on, from power supply, and runns continously. It doesn't work on hot water or heating.
Even if the control switch is turned to 0 the fan doesn't stop.
The front panel shows a fault on the Air pressure switch - this has been replaced with no success.
If one of the air pressure switch hozes is taken out and put back on when there is demand for hot water or heating, the flame comes on and runs for as long as there is demand for it. Once off this needs to be repeated in order to re-start the flame.
Any ideas?
Any ideas?
