I have a Glow-worm Betacom 30c boiler and recently the pressure of the hot water coming out of the taps is very poor. The water is being heated to a sufficient temperature and the pressure on the boiler is currently sitting at 1.7 on the display gauge. About a month ago, this was investigated and the filter removed, checked, cleaned out (there was one very small piece of grit present) and replaced. After which, the hot water pressure at the tap had improved. It has however now reduced back to what it was before the filter being removed and cleaned out.
Any suggestions on what else can be done or investigated to improve the hot water pressure. I am aware that the water pressure coming from the hot tap is never going to be as good as if the water was coming from a storage tank, but surely it can be back to what it was a month ago.
Thanks.
Thanks.
