Would be grateful for any advice. My Glow worm combi boiler (16-18 yr old) is heating radiators fine, but a few weeks ago starting producing only luke warm water. This morning after the central heating was off all night, only cold water came out the hot water. This evening (the central heating had been on a few hours), some hot water came out followed a few minutes later by just luke warm water. Is this most likely the heat exchanger or diverter valve or neither? Not sure if relevant but since the summer the boiler has leaked intermittently which I was told by someone in the know, that it was likely the o-rings. Could this be a clue it’s the heat exchanger being the current problem? Thanks in advance for your advice - Katherine - total novice diyer
