It started as something so simple. Boiler ran ok but loosing pressure through the PRV - which i replaced. Here starts the tail of woe...
First - no fan on ignition! Found loose connection in supply. Reterminated ok. Then tested.... then had some arcing on the PCB.... which i dont believe was wet at all.... from a transistor (i think).
Now the main gas valve does not seem to be opening fully. Have ignition and a very small flame encirles the ignition probe, not enough for the sensor to be happy and lock out.
Now i am pretty certain the card has gone - arching etc. No visible damage though.
Q. No U gauge with me so.... want to check the PCB output... how do i test the power supply to the gas valve???
Valve is a Honeywell VK4104G. What voltage should i expect on the feed to it on ignition?
Am i missing something?
ta
Kev
ta
Kev
