Hello all
I have a Glow worm Compact 75p it about 9 years old. It has recently had the fan replaced, as the bearings had gone. The problem I have now is it is either on or off. I bought a new clock / timer as I thought this may be the problem, but no still the problem exists. I can push the pins in for the times I want the boiler on, click the switch to the programmed position and the boiler fires up. However it wont switch off when it gets to the points on the timer where it is supposed to. Even when you slide the switch to permanently off it stays on! The only way to stop it is to flick the on/off rocker switch, which means no hot water! Any ideas? Could the PCB need replacing?
Thanks all
Rich
Thanks all
Rich
