GLOW WORM CRAP
15 Apr 2008
have had problem with my glow worm boiler so phoned glow worm fix price fee £260 for repair what a load of rubbish the engineer came he had not got a clue what he was doing could not fix it and then charged us £80 call out BEWARE DONT CALL GLOWWORM RUBBISH
I don't think they should be doing that.
Instead of rubbishing them I would suggest that you comp[lain to them that he failed to fix it, charged you a fee, and ask them to send someone who can.
I now wonder if that is the G-W policy to charge if they cannot fix? Or tit went into the engineers pocket?
OR are you not telling us the full truth and it was all sludged up which they will NOT fix.
An independent is likely to be cheaper and will do any work required to repair.
Tony Glazier
It depends, if it was not a problem with the boiler and the fault is system related then they will charge you for the privilege of calling them out. They will only fix a boiler problem on the £260 fixed repair. If you'd of gone for the slightly more expensive cover, they will cover some system faults and you get 12 months boiler cover as well. What boiler do you have and what is the problem.
