Glow Worm Energy 35 Store combi
Unvented every time. If you have the space it's a much better option. Storage combis are huge, expensive and difficult to repair. Most will run away if it needs fixing. An unvented cylinder has the backup of an immersion heater if the boiler has a fault and can supply as many outlets as your water supply can cope with. A storage combi cannot.
thanks wannocks
the mains flow at the moment is only 10/12 ltrs which isnt adequate for an unvented system it seems. could you suggest if having an unvented cylinder will atleast provide 10/12 ltrs to simultaneous taps or showers?
If your Max mains flow rate is 10-12l/min at one tap then it will split down when running multiple taps, ie maybe 7l/min at one and 4l/min at the other.
No point in a cylinder or a storage combi at that flow rate, a standard 30/35kw combi will heat that fine, but may be even less of a flow rate once it passes through any sort of combi/storage unit or cylinder
As SGM said. Didn't spot the flow rate, I was thinking about the unvented v storage combi question. Better to see if anything can be done to improve your mains flow rate or stick with gravity.
SGM, Wannocks - thanks again
yes, I am exploring the possibility of upgrading the lead supply pipe coming into the property to wider poly pipe. I wonder though if it is generally adequate just to upgrade the pipe from the external boundary stop-cock to the internal stop cock? Replacing the internal cooper works in the property isn't an option for me at this time..
