Glow-worm FF50 Micron not firing
18 Nov 2011
I've been having intermittent problems with my FF50 boiler whereby the system tries to start but then fails resulting in the RESET button flasing green (fast) and the burner on button flashing green (blinking).
The problem started last friday morning, however, after I had called Glow Worm to arrange a repair I did one final reset and it started working again, however, the same problem has arisen today.
Over the last few months the boiler has got noisier and the fan does make more noise than normal ( it can be heard upstairs in the front bedroom, flue is at the back of the house.
I was going for the fixed deal of £285 from Glow Worm thinking it was the PCB gone AGAIN!!!! but now I'm not sure.
Anyone any ideas if the green flashing lights have any significance in identifying the problem.
Any help greatly appreciated.
Green flashing light is a lockout,MAY be pcb again,but could be the ignition probe,or the thermistor that goes in the top of the heat exchanger.
