I have come home to find the boiler in fault mode flashing F1.
Other than some initial F22 fault codes before outside pipe was lagged it has always run 100% but now have this fault.
Pressed the reset and it has fired with a bit of a whoosh when the flame lit. The wife has now explained that it locked out the other day and when she reset it it made the same louder than normal woosh at ignition. After firing after lockout it continues to work as it should seemingly if nothing is wrong.
Good old google seems to point towards ignition fault so is it failing to light and locking out?
Unit is approx 4.5 years old and to be fair isn't serviced bang on schedule.
Is it likely a service will cure the fault or is it a known fault that needs parts. Either way planned on getting it serviced just hoped to have some opinions on what the fault is and cost to repair etc. to forewarn the impending service engineer
Thanks as always for your responses
